It’s already mid-November, so Black Friday is just around the corner, only two weeks away. If fact, INKBIRD’s Black Friday event has been going on for two weeks now. If you are a loyal fan of INKBIRD, you’ve probably saved a lot in the first two weeks.
From November 15th to November 21st, INKBIRD is rolling out a Sous Vide Deal featuring sous vide cookers, vacuum sealers, and other handy kitchen gadgets. Let’s check out what discounts are available and which products are must-haves!
When is the Sous Vide Deal?
INKBIRD will be rolling out a new themed deal each week in November leading up to Black Friday. The Sous Vide Deal kicks off on November 15 and lasts until November 21. After that, get ready for the BBQ Deal, followed by Black Friday and Cyber Monday sales.
INKBIRD Sous Vide Deal
What Products Are There? What to Buy?
This exclusive Sous Vide Deal is available for a limited time and covers various products across different categories. If you’re feeling unsure about what to choose, we’ve added some recommendations for each category to help you make your choice.
Sous Vide Cookers
Sous vide is a cooking method where food is sealed in heavy-duty bags with all air removed and submerged in a water bath set to your preferred temperature. This technique ensures that proteins like steak and chicken are cooked to perfection while retaining tenderness and moisture. Although sous vide was often found in high-end restaurants, it’s now a hit at home thanks to more affordable sous vide machine.
During the Sous Vide Deal, INKBIRD’s immersion circulator is up to 40% off. Here are some buying suggestions:
For everyday cooking, check out the latest ISV-101W, which heats water quickly and maintains the temperature steadily. It has a large color screen that displays preset menus, temperature, and time, and you can connect it to your smartphone via 2.4GHz WiFi for more options.
ISV-101W Sous Vide Cooker
If you’re looking for a waterproof option, the IPX7 ISV-300W can definitely satisfy you. It uses 3D water circulation for even heating and has precise temperature with only a ±0.3°F/±0.1°C error margin, ensuring your food stays tender and juicy. For more details, refer to: ISV-300W Sous Vide Cooker Review.
Lastly, if you prefer an all-in-one solution, the ISV-500W combines a water oven, immersion circulator, and rack. Similarly, it can also be connected to your phone via WiFi for remote control, and has a variety of preset menus, allowing you to make restaurant-level delicacies.
ISV-500W Sous Vide Cooker
Vacuum Sealers
A vacuum sealer works by sucking air our of bags and then sealing them with heat, which prevents food from spoiling and extends its shelf life. This method is the best way to save steaks, cheeses, and pasta. If you’re curious about the shelf life, see: How Long Does Vacuum Sealed Meat Last?
During the Sous Vide Deal, you can snag INKBIRD’s vacuum sealers at a discount of up to 20%. Here are some buying tips:
For compact option, the INK-VS01 is a great choice. It’s small, lightweight and features a bag cutter, though it lacks a built-in bag slot.
INK-VS01 Vacuum Sealer
If portability is what you need, the INK-VS06 is perfect with its rechargeable battery, which allows for up to 110 seals on a single charge and is great for picnics.
For those seeking top-of-the-line features, the INK-VS04 offers a removable water tank for easy cleaning, a handle for one-handed use, powerful -80kPa suction, a specific mode for sealing liquids, and more.
INK-VS04 Vacuum Sealer
Kitchen Gadgets
INKBIRD offers more than just sous vide cookers and vacuum sealers. They also have kitchen timers IDT-01 and IDT-02, as well as the electronic scale IBFS-01.
IDT-02 Kitchen Timer
Where to Find Coupons and How to Use Them?
To get to the Sous Vide Deal page, simply click the event banner on the homepage, or go to “Sale > Sous Vide Deal” in the top menu. You can also use this Sous Vide Deal link to go straight there. Once you’re on the page, you’ll find various discount codes for different products. Just copy the code you want to paste it at checkout page to use it.
How to Find Sous Vide Deal
When is Black Friday 2024?
Black Friday is always the Friday right after Thanksgiving, and this year it’s on November 29, 2024, which is only two weeks from now.
What Black Friday deals can you expect from INKBIRD?
Black Friday always offers great deals on all sorts of products, and INKBIRD is mixing things up with a themed sale each week in November, offering deep discounts on smart IoT devices.
This week, from November 15 to 21, the spotlight is on sous vide cookers, vacuum sealers, and kitchen gadgets with discounts reaching up to 40%. Next week, you can score up to 50% off on meat thermometers, smoker fan controllers, and instant-read thermometers.
When the big day hits, everything on INKBIRD site will be on sale, and buying in bulk means even more savings. For more details, check out INKBIRD Black Friday Sales Overview
Should I buy sous vide items now or wait until the big day?
Gone are the days when Black Friday had the best discounts. In recent years, you might find better deals leading up to it. So don’t leave it to chance. If you see something you want on sale, just grab it! Shopping early not only could get you a potentially better price than Black Friday, but also help you avoid the chaos of the day. Don’t let this opportunity slip away, or you might be stuck waiting until next year.
