Technology is evolving so fast! You might be sticking to the same kitchen gadgets for every meal, but it’s clear that smart tech is seeping into every aspect of our lives, including kitchen appliances. If you’re anything like me, you love to whip up delicious meals but also crave a little bit of convenience, this guide will help you understand what a smart kitchen is, and share 5 appliances that can make your connected kitchen truly smart.
What is Smart Kitchen?
Traditional kitchen appliances often fall short with their single functions and complex operations, making it difficult to meet the diverse needs of modern families to cook efficiently, safely, and healthily. A smart kitchen, on the other hand, resembles the futuristic cooking spaces seen in The Jetsons, integrating advanced technologies like the IoT and AI to streamline your culinary processes and even add a bit of fun.
These smart kitchen appliances not only improve cooking efficiency, but also expand your culinary possibilities. You can control them remotely via smartphone apps, such as preheating oven, monitoring food temperatures, or automating cooking tasks with ease. They can even intelligently adjust cooking settings based on the type and amount of ingredients, ensuring that every meal is perfectly balanced in taste and nutrition.
What’s more, with built-in safety features like anti-dry burning alerts and automatic shut-off for overheating, smart kitchen appliances help eliminate potential hazards from user errors or equipment issues.
5 Best Smart Kitchen Appliances
The idea alone might not fully capture how these smart kitchen gadgets can transform the way you cook and simplify your daily routine. So, let’s dive into the top 5 smart kitchen appliances!
1. Smart Meat Thermometer
Have you switched from that old instant thermometer yet? You really should check out a smart meat thermometer. These gadgets connect to your phone via Bluetooth or WiFi and notify you when your meat reaches the perfect temperature. Some models, like the four-probe INT-14-BW, can even monitor several meats at the same time. On top of that, the accompanying app has recipes included, so even if you’re not a cooking whiz, you can grill, roast, or smoke like a pro just by choosing the meat you’re cooking.
Smart Meat Thermometer App
2. Smart Sous Vide Cooker
If you’ve been to any fancy French restaurant, you’ve probably heard of the sous vide cooking method. This technique involves cooking food in a water bath at a low, precisely controlled temperature for a long time, resulting in incredibly tender and juicy dishes. With INKBIRD sous vide cooker, you can manage the cooking temperature and time right from your phone. Just set it up, drop the vacuum-sealed food in the water bath, and let the technology take care of the rest.
3. Smart Oven
While a smart oven might seem like unnecessary, it’s actually one of the best addition to your smart kitchen. Think of it as your own personal chef that adjusts cooking times and temperatures to whatever you’re preparing. Some models even have built-in cameras, so you can easily check on your food without leaving the couch. Additionally, many smart ovens feature sensors for roasting and baking that can tell when you food just likely done.
Smart Oven
4. Smart Fridge
Smart fridges might cost more than regular ones, but I think they’re totally worth it. I’ve had mine for three years and I still love it. The front has a tablet that connects to the internet, offering all sorts of cool features. One of my favorites is the built-in camera that tracks my food remind me when they are about to expire. This is also useful for grocery shopping, as I can check what I have remotely. Furthermore, when I’m stumped on what to eat, I will let it recommend recipes based on what’s inside.
Smart Fridge
5. Smart Kitchen Scale
I think every cooking enthusiast should have a digital scale in their kitchen, but trust me, you definitely need an extra smart kitchen scale, especially if you’re into fitness or nutrition. It can connect to your smartphone to help you accurately measure ingredients, record what you eat, and check nutritional information. Some can even recommend recipes based on what you’re weighing.
Smart Kitchen Scale
1. Are smart kitchen appliances worth the investment?
Absolutely! They might cost a bit more upfront, but the convenience, time-saving benefits, and improved cooking results usually make them worth it in the long run. If you’re still on the fence, you could try starting with a simple smart meat thermometer, which typically costs a few dozen dollars.
2. Do I need a smart home setup to use these appliances?
Not necessarily. While many smart appliances work best with a smart home system, most can be used independently with their respective apps.
3. Can I control all smart kitchen appliances from one app?
It depends on brand and compatibility. Some brands come with their own apps, while others can connect with smart home systems like Google Home or Amazon Alexa. For example, you can manage all INKBIRD smart kitchen appliances and even smart home gadgets through the INKBIRD app.
4. Do I need WiFi for smart kitchen appliances?
Not necessarily. While most smart kitchen gadgets require WiFi to work properly, some can connect through Bluetooth, such as the INT-11P-B wireless meat thermometer.
5. What is my WiFi goes down?
Most smart kitchen appliances have backup settings, and can still function manually. However, you might miss out some smart features without a connection.
6. Can I use smart kitchen appliances if I’m not tech-savvy?
Yes, many of these devices are designed to be intuitive and user-friendly, so you don’t have to be a tech whiz to take advantage of what they offer.
