Whether you're a grill master or just a barbecue enthusiast, you should know that controlling meat temperature while cooking is crucial. For precision cooking, using a kitchen thermometer is necessary, and a Bluetooth thermometer can enhance your cooking abilities significantly. These Bluetooth thermometers are suitable for most scenarios, such as grilling and smoking. The best thing is that you can remotely monitor the temperature through your smartphone app. To help you make a well-informed decision, we have conducted multiple rounds of tests on the Bluetooth meat thermometers in this article.
RELATED: How to Choose INKBIRD Wireless Meat Thermometer?
Why Do You Need A Bluetooth Thermometer?
A meat thermometer is essential for meat cooking, which allows you to keep track of the internal temperature of the meat. As an advanced option, Bluetooth meat thermometer is more convenient as you can monitor the temperature from anywhere within range. This means you can relax and enjoy your time with friends and family without having to constantly check on your grill or oven.
1. INT-14-BW
After evaluating the cost, functionalities, and precision in temperature, our testing team unanimously ranked the INT-14-BW as the best Bluetooth thermometer for meat cooking. What we like is absolutely the combination of its four true wireless probes and the triple-threat connectivity. Being able to monitor a brisket, two racks of ribs, and the ambient oven temp simultaneously from my phone via WiFi
The smart app features - like the 4-alarm system and 26 USDA-preset menus - take the guesswork out of hitting perfect doneness every time. Add in the 25-hour battery life, IP67 waterproof probes that are dishwasher-safe, and the convenience of a fast-charging magnetic base, and this feels like a premium, no-compromise tool.
Best Bluetooth Meat Thermometer INT-14-BW
What we like
What we dislike
  • 3-mode (WiFi/Bluetooth/Local) connectivity
  • 4 true wireless meat probes
  • Smart, feature-rich app with Apple Watch supported
  • Excellent battery life and charging speed
  • IP67 waterproof and dishwasher-safe probes
  • The Bluetooth connection range could be longer
2. INT-12-BW
While many other thermometers have two probes, they are of the same length and often fall short for smaller cuts of meat like salmon fillets or chicken legs. Featuring a long and a short probe, the INT-12-BW can effectively address this issue.
As one of the best Bluetooth meat thermometers, the INT-12-BW supports dual connection modes - 5GHz WiFi and Bluetooth 5.4 - automatically switching between them to keep you connected. It also has a full-view screen, so you can monitor the temperature while grilling without needing your phone. Plus, it is also IP67 waterproof and dishwasher-safe.
Best Bluetooth Meat Thermometer INT-12-BW
What we like
What we dislike
  • Long and short probe for different cuts of meat
  • WiFi and Bluetooth dual connection
  • IP67 waterproof, dishwasher-safe
  • 28 types of meat menus
  • Full-view-angle HD LCD screen to check temperatures locally
  • The short probe can only detect food temperature
3. INT-11P-B
The INT-11P-B adopts 5.1 technology, enabling a control range of 300ft. It has 2 sensors, one for meat temperature and the other for ambient temperature, which helps you simultaneously monitor 2 necessary temperatures, and also helps the app determine when your meat is cooked to perfection.
The accompanying app can be downloaded for free from the manual. It contains more than 26 preset menus, and of course, you can customize them according to your preferences. What we like best is that it comes with a charging case, just like the case of your AirPods. You can put the probe in the case when you are done using them, and it will charge instantly and be ready for use next time.
Best Bluetooth Thermometer INT-11P-B
What we like
What we dislike
  • 300ft/91m Bluetooth distance
  • IP67 waterproof, dishwasher safe
  • 26 preset menus
  • Steel probe and ceramic handle
  • Minimalist charging case with fast charging
  • No WiFi connection
4. IBT-26S
If you want to measure multiple meats at once, then the IBT-26S provides you with a different option. In addition to being a Bluetooth BBQ thermometer, it is also a WiFi thermometer, supporting 5GHz or 2.4GHz WiFi networks. IBT-26S can accommodate up to 6 probes (5 for meat and 1 for oven), providing more accurate temperature readings compared to the INT-11P-B, despite it requires cable connections to the main unit.
With 29 USDA-recommended meat cooking presets, the IBT-26S is ideal for beginners who want to cook restaurant-quality meals. Through Bluetooth or WiFi connection, you can receive timely alarms like high/low-temperature alarms, device over-temperature alarm, etc. Maybe you prefer to monitor your cooking by the oven or grill, then the built-in LCD offers clear data display.
Wireless BBQ Thermometer IBT-26S
What we like
What we dislike
  • Accurate temperature measurement
  • 4 meat probes
  • Bluetooth, 2.4GHz/5GHz dual connectivity
  • 29 preset menus
  • Magnetic back and foldable stand
  • Not true wireless
5. IBT-2X
If you are on a budget and only need 2 probes, then the IBT-2X is a better cost-effective option, which is pretty much the cheapest Bluetooth cooking thermometer you can find. It can be easily managed through Bluetooth using the INKBIRD app, with the range of up to 150ft/50m. When the temperature hits set thresholds, IBT-2X will trigger alarms.
In case where your phone is on silent or vibrate mode, the built-in timer can be useful for monitoring and setting cooking times. What’s more, IBT-2X stores offline data which can be accessed through the app. Despite having 11 preset menus, it can basically meet your cooking needs.
What we like
What we dislike
  • Budget-friendly
  • Built-in timer
  • High/low temperature alarm
  • Store offline data
  • Probe is not waterproof
Comparison
The comparison chart provided below will offer a clear overview of each Bluetooth thermometer mentioned above, helping you select the most suitable option for your needs.
Model
INT-14-BW
INT-12-BW
INT-11P-B
IBT-26S
IBT-2X
Bluetooth
5.4
5.4
5.1
5.1
WiFi
2.4GHz
5GHz/2.4GHz
x
5GHz/2.4GHz
x
Display
x
Connect Distance
300ft/91m
328ft/100m
300ft/91m
230ft/70m
150ft/50m
Probes
4
2
1
Up to 6
2
Sensors
2 in 1 probe
Long probe: 2
Short probe: 1
2 in 1 probe
1 in 1 probe
1 in 1 probe
Food Temperature Range
14~212℉ (-10~100℃)
Ambient Temperature Range
32~572℉ (0~300℃)
Measurement Accuracy
±1.8℉/±1℃
±1.8℉/±1℃
±1.8℉/±1℃
±0.9℉/±0.5℃
±2.0℉/±1℃
Preset Menus
26
28
26
29
11
